Fixed my water leak, last night!!
Old 04-02-2010, 09:47 PM
c2vette's Avatar
For 2008/2009 with leaks, this seems to indicate the 2008/2009 don't have this specific leak location. https://www.chevyhhr.net/forums/show...2water+leak%22
c2vette is offline
Old 11-14-2010, 08:30 PM
scuba05477's Avatar
Originally Posted by tooter1
1. Remove the left and right wiper arms. Pop off the cover and use a 15mm socket to loosen the nut.
With the hood still up, lift the drivers side and it should remove pretty easily, the passenger side will be a little more difficult, I had to remove the blade assembly, but I got it off.
2. Remove the four 7 mm screws (be patient they are about 2.5 in. long) and the two push-in retainers from each side of the grille panel.
3. Remove the five wire harness retainers from the grille panel.
4. Lift the panel up and place it on the engine or off to the side after you unplug the washer fluid hose.
5. Then you will see the patch that was causing my problem.
6. I removed the butyl patch and cleaned the area with sticker remover. On the car and on the butyl patch.
7. Ran a bead of black rtv silicone sealant around the patch, let it sit about 3 minutes then reinstalled on the car and pressed down around the edges to make a better seal.
8. Installation is the reverse of removal, just don't forget to tuck the weatherstrip into the side weatherstrip that runs down the fenders.
Very nice write up and photos! Did this on my '06 today. I hope it does the trick. Thanks for your help.
scuba05477 is offline
Old 03-18-2011, 12:26 PM
Dunny's Avatar
Replaced patch last nite. New patch was about $10. It's better than the old flimsy black rubbery one! They are now a much stiffer, transparant piece of plastic with the adhesive already on it - Just peel off the paper and slap the new one on.
Dunny is offline
Old 03-19-2011, 11:19 AM
briand's Avatar
Dunny, where did you buy your replacement piece? This was repaired once under warranty for me on my 2006 2LT. I have a feeling it may soon become an issue again and want to repair it before it becomes an issue.
briand is offline
Old 03-20-2011, 11:44 PM
Dunny's Avatar
Water leak
Hi Briand - I think I got it here:
http://www.gmpartsdepartment.com/par...=7&catalogid=2
Dunny is offline
Old 03-21-2011, 12:00 AM
  #26
Dunny's Avatar
water leak
Briand - This is another web-site that has the water deflector:
http://www.partswebsite.com/hendrick...122&type=parts
Dunny is offline
Old 04-11-2011, 07:33 AM
  #27
barfan1's Avatar
Passenger side water leak
I had a small leak from the cowl area also. The thin rubber or plastic patch GM provides is too flimsy to keep water out. Even if you go buy a brand new seal, it will fail in again. The permanent fix is what some others have done. Get a thin piece of aluminum or steel, 26 gauge is fine, and trace the cover and cut it out. Make the two screw holes as small as possible for better sealing. Then use black RTV sealer/adhesive all around the edge and put the new patch back into place. I put some weight on the cover and waited an hour or so for the RTV to set up. I then took some aluminum tape and covered the entire new patch to ensure a water and air tight seal and put the cowl back on. A permanent fix to the problem.
barfan1 is offline
Old 05-01-2011, 11:17 AM
  #28
SenexBowtie's Avatar
Thumbs up Thanks!
Thanks for going to the trouble of posting this. My problem was exactly the same (including my fan speeds). I did the repair this morning; now, I'm just waiting on rain!
SenexBowtie is offline
Old 06-25-2011, 10:30 AM
  #29
JJBoxer1's Avatar
Wow Thanks Tooter you save me some bucks, I'm having that same problem, but I have to wait until it dry up around here, been getting lots of rain against my wishes, but soon as it is clear I will be all over it, thanks again man, to bad the dealers counldn't figer this out with a price tag on it.
JJBoxer1 is offline
Old 07-07-2011, 01:54 PM
  #30
JJBoxer1's Avatar
Got it dine
Thanks to Tooter I got my water deflector fix today, when I took the crowl off today, the patch was sitting down in the hole, I took it out cleaned around the area, then applied the sillicone, waited a few minutes, then put my new deflector on, I press down on it all the way around then let it sit for about and hour before putting everything back together, now all I have to do is wait for the rain to come, now I needing to fix that stupid Sunroof wind deflector, and everything would be all good.
JJBoxer1 is offline
Quick Reply: Fixed my water leak, last night!!
