Problem With HP E47 tune
Old 08-25-2016, 01:20 AM
Nazgul 9
Guest
Posts: n/a
So I finally got the HP E47 tune loaded onto my ecm.. and its idling crazy... up down...up down....and i have a p0557 code....any ideas???
Thanks
Vince
Old 08-25-2016, 02:10 AM
Have you looked up the code? ie: P0557 Brake Booster Pressure Sensor Circuit Low Voltage OBDII Engine Light Trouble Code | Engine-Codes.com
whopper is offline
Old 08-25-2016, 03:03 AM
Nazgul 9
Guest
Posts: n/a
I am sorry I should have stated I did indeed look up the code I was wondering if anyone else had this problem or this code???
Old 08-25-2016, 09:50 AM
Using the SEARCH tool at the top of the page showed only 1 thread discussing the p0557 code - and traced it back to a bad connection - https://www.chevyhhr.net/forums/hhr-...-20946/page14/
But it is a thread from way back in 2009.
whopper is offline
Old 08-25-2016, 10:57 AM
Technical Moderator
I am thinking the erratic idle is causing the brake booster problem, or the brake booster vacuum line is disconnected
donbrew is offline
Old 08-25-2016, 11:36 AM
DrLoch's Avatar
Lets back up here for just a second.
Who's tune is it? Was it fine before you put the new tune in?
DrLoch is offline
Old 08-25-2016, 11:56 AM
Nazgul 9
Guest
Posts: n/a
Its 2005HHRAUTOS E47 HPTune and it is a new ecm just got flashed had no problems or codes...
Old 08-25-2016, 12:02 PM
Technical Moderator
Same sensors as 2005HHRAUTO has?
donbrew is offline
Old 08-25-2016, 12:04 PM
Nazgul 9
Guest
Posts: n/a
do you mean 2bar or 3 bar?? cause I am honestly not sure and I was thinking about that myself...
Old 08-25-2016, 12:23 PM
DrLoch's Avatar
Bingo. He's using 3 bar sensors, if you haven't changed your sensors that is your issue. Put the stock tune back in it and do some more reading.
DrLoch is offline
Quick Reply: Problem With HP E47 tune
