I've lost boost after BOV replaced!
Old 10-28-2016, 08:47 PM
SS34's Avatar
I just did this mod. After about an hour or so I lost all boost. Car is fine but when I accelerate there's no boost whatsoever. Everything is installed correctly. There's some oil on the bpv i don't have any idea why. Any help will be appreciated.
SS34 is offline
Old 10-29-2016, 08:18 AM
DrLoch's Avatar
My suggestion, please start an new thread and add year, auto-manual, miles and anything else you have done to the car before this happened. Also, pull any codes although some times it may not throw a code. Oil in the BOV is somewhat common, read the threads about catch cans for more information.
DrLoch is offline
Old 10-29-2016, 11:14 AM
Weird. I answered this new thread and it posted to the old one. Guess I'll wait till the mods get done moving everything.
firemangeorge is offline
Old 10-29-2016, 11:51 AM
Well. After reading the OP's other thread: https://www.chevyhhr.net/forums/ss-s...n-turbo-57501/
I can see he'll need to post up some history info before I'll try to guess.
Fwiw. 2 months ago he was having issues. He never bothered to follow up on that thread he started.
Old 10-29-2016, 02:20 PM
Technical Moderator
But if the first line of one of the DTC says "The P2261 diagnostic trouble code is an indication that the turbo/super charger bypass valve mechanical control circuit is giving the Powertrain Control Module (PCM) a reading that is abnormal. " Wouldn't you replace the BOV?
donbrew is offline
Old 10-30-2016, 08:53 AM
DrLoch's Avatar
Well.
If he comes back we may be able to help point him in the right direction.
donbrew, thanks for starting new thread and moving post.
DrLoch is offline
Old 10-30-2016, 08:59 AM
Technical Moderator
Wasn't me, I was surprised by it.
donbrew is offline
Old 10-30-2016, 10:25 AM
I moved this into a new thread.
Oldblue is offline
Old 10-31-2016, 07:25 AM
DrLoch's Avatar
Thanks OB
DrLoch is offline
Old 10-31-2016, 08:39 AM
Your welcome! It was your suggestion.
Oldblue is offline
Quick Reply: I've lost boost after BOV replaced!
