2.0 Intake
Old 03-06-2015, 02:03 PM
2.0 Intake
Will a HHR 2.0 Ecotec turbo intake fit and work with a HHR 2.2 Ecotec engine?
Boydie
Blue Beast (aka Boydie) is offline
Old 03-07-2015, 02:56 AM
I suppose the answer would depend on whether you're turbocharging the 2.2 or leaving it normally aspirated.
843de is offline
Old 03-07-2015, 10:01 AM
OK let me clarify: Will a 2.0 turbo head fit on a 2.2 if I wanted to turbocharge the 2.2?
Boydie
Old 03-07-2015, 10:24 AM
2.0 and 2.2 have different bore and stroke, so No on that account.
firemangeorge is offline
Old 03-07-2015, 11:38 AM
Thank you fireman.
How do Willwood brakes compare to Brembos?
Boydie
Old 03-07-2015, 12:36 PM
That would depend on rotor diameter and number of pistons in the caliper for clamping grip.
Oldblue is offline
Old 08-25-2015, 11:28 AM
skates's Avatar
The bore & stroke of the eng has NO EFFECT on if the head will interchange you'd be best to look at head gaskets of each head if the bolt holes won't line up then don't try it if they do then you need to check if cam belt or chain is the same..
skates is offline
Old 08-25-2015, 11:42 AM
On most heads, there is a "chamber" or space or recess that the valves fit into. The chamber diameter size matches to the bores diameter.
Stroke may not be a factor, but the bore sure can be.
drummerboy0088
2.2L Performance Tech
19
02-10-2015 12:25 PM
Michael20832
2.0L Performance Tech
07-08-2009 05:16 PM
Quick Reply: 2.0 Intake
