airraid hose line
airraid hose line
i kno every one talks about this intake but it has a hole in the box where does it run to? and if it could be moved should i put it where the fog light caps are with a small mesh screen?
The hose off of the stock air box runs to the passenger side front fender and picks up fresh air from inside there. As for running it down to the fog light opening, you could try but how to get it down there might be a fun task. Good luck
en0oNmAI
2.2L Performance Tech
27
12-13-2006 10:27 AM
