check eng light
Old 11-26-2014, 10:28 PM
There is no code that says an 02 sensor is "bad". A P0053 code shows that the 02 sensor is having readings that are not within the specified range.
P0102 points to a Mass Air Flow sensor issue.
Both of these codes need diagnostic work done to find the reason for the fault. Most likely the P0102 code is causing the P0053 code to be set.
P0043. I don't even see that one on the trouble codes listing. That may just be a false code.
Pulling the battery cable to clear the codes ? Why ? You've got the codes, now it's time to find the fix.
firemangeorge is online now
Old 11-26-2014, 10:37 PM
walkowg's Avatar
because I was geting the same code before i replaced the o2 sen aka code poo53 mabe it did not get clear the frist time does not hurt anything
walkowg is offline
Old 11-26-2014, 11:23 PM
sbrice54's Avatar
P0043 is o2 sensor Heater Control Circuit Low Bank 1 Sensor 3
sbrice54 is offline
Old 11-27-2014, 06:09 AM
Since the HHR has no sensor 3, then I would assume this is a false code that walkowg was given by the code reader.
Old 11-27-2014, 10:00 AM
Technical Moderator
My Torque app keeps insisting that my bank 4 sensor 4 and bank 2 sensor 2 are giving bad readings.
donbrew is offline
Old 11-27-2014, 10:10 AM
Technical Moderator
When I Googled p0053 I found this: P0053 Chevrolet HO2S Heater Resistance Bank 1 Sensor 1 OBDII Engine Light Trouble Code | Engine-Codes.com
p0102 returned this: OBD-II Trouble Code: P0102 Mass Air Flow (MAF) Circuit Low Input
And I did a tiny bit of research about p0043, some say that it relates to the rear O2 sensor heater, not necessarily #3, in our case that would be #2.
All 3 mention wiring harness as a possible fault.
sounds like a duck, walks like a duck ........
donbrew is offline
Old 11-27-2014, 10:03 PM
walkowg's Avatar
thanks for the info on p0043 will try to look at it sunday
walkowg is offline
Old 12-03-2014, 11:36 PM
walkowg's Avatar
Up date to my check eng light . A freind just traded for a real nice scan/eng checker made by snap-on . So we hook it up to the HHR and reset the code after i made sure all we had was the one auto zone said i have. So far light is still off and been off for 3 days and 400 miles so we may be good. So i guess i need to leave the battry off longer next time.
walkowg is offline
Old 12-04-2014, 12:13 AM
Negative cable disconnected for a minumum of 30 minutes to perform a successful "Code Clearing Lobotomy" on an HHR.
Of course a "Lobotomy" is only a way of returning your vehicle to a code free baseline.
If a CEL pops up again, it's important to pull the codes and attend to the fault.
843de is offline
Old 12-04-2014, 06:15 AM
Technical Moderator
After codes are cleared it can take more than 2 weeks for the monitors to run.
donbrew is offline
Quick Reply: check eng light
