Codes C0292 P0013 P0014 HELPPPPP
Old 12-29-2016, 10:23 AM
Nothing about the starter!!
https://www.obd-codes.com/p0013
https://www.obd-codes.com/p0014
Because these two codes effect the camshaft timing then the C0292 code relates to timing problems, it will go away after the solenoids are replaced.
http://c0292.enginecodes.net/
Get another mechanic, this one is guessing and blowing smoke at you!
Oldblue is offline
Old 12-29-2016, 10:26 AM
So your mechanic says replace the starter but based on what ? There is no code that says a starter is "bad".
As we tried to tell you above, the P0013,14 codes relate to the camshaft solenoids. The members on here have 1st hand knowledge and experience with these codes and the fix. Not sure why you can't seem to acknowledge this. Did you read the links posted ?
Personally I'd find a different mechanic. If they think throwing a starter on there will fix those codes, they're in for a surprise.
firemangeorge is offline
Old 12-29-2016, 10:28 AM
Sydnika's Avatar
C0292 Engine Code Meaning - C0292 Engine Trouble Code - How To Fix C0292 | EngineCodes.net
Thank you. I'm looking for another mechanic now
Sydnika is offline
Old 12-29-2016, 10:29 AM
Sydnika's Avatar
Sydnika is offline
Old 12-29-2016, 10:54 AM
Good! You really don't need one, just a few simple tools will do. Even with no automotive experience!
Just follow the directions or maybe you have a guy in your area, a friend or relative with a little car knowledge.
Oldblue is offline
Old 12-29-2016, 12:19 PM
aradmahogany's Avatar
Just BE CAREFUL when pulling the solenoids out. They can give resistance. I did mine nearly three years ago and they have been fine since. I did something right . I did accidentally break one of the plug retaining clips though but its been fine. You have to make sure to remove the clips before unplugging the connector.
aradmahogany is offline
whopper
"How To" Tutorial Library
633
07-18-2016 01:28 PM
fjauslin
08-31-2015 10:46 PM
sam4svita
12-24-2014 08:51 PM
dkennedy1282
11-17-2014 09:22 AM
macgyver6046
03-27-2014 10:51 PM
Quick Reply: Codes C0292 P0013 P0014 HELPPPPP
