Codes P0016, P0101, P0102, P0113
So, it runs smooth. Has a bad bog and no power. Plus major brake fade. Hell to stop. 60 mile trip to the city and back. Still runs nice.
Before I completely F it up I'm bringing it to a friend that runs a shop.
Not our only transportation (two motorcycles and a 01 Ram) but definitely not the one I want down.
All I did originally was swap tensioner. You know how easy that is. That alone has brought on everything else. No vacuum leak found.
The brakes work fine when first started with codes clear then minutes later hard pedal. Disconnect battery, drive away, still bogs. Block away the light comes on and brakes fade.
Still have done no changes except tensioner.
Check the vacuum tube to the booster, it may have gotten jiggled or cracked.
There is NO other way that the brakes could be affected Except a coincidental failure. How about the check valve being loose or malfunctioning?
Somebody, not long ago, managed to crack the elbow on the intake manifold. We never heard how.
JB Toronto SS
11-21-2017 09:08 PM
Dracos
04-06-2013 11:33 AM
JB Toronto SS
06-24-2010 07:56 AM
