leaking struts?
Old 12-07-2012, 12:24 AM
jeff schaffer's Avatar
leaking struts?
So today I had to get new tires and found out that the driverside
Strut had blown out the ? Is how long can I drive on the strut
Should have the money in a few days to fix the strut and get kyb's.
jeff schaffer is offline
Old 12-07-2012, 08:43 AM
Musicguy's Avatar
You could drive on it forever, the spring is what holds up the car, the strut controls rate of compression and rebound. There is a chance that eventually you will get some odd tire wear, and depending on how blown it is some odd handling. I drove on mine for a few months before I got around to changing the struts, I needed new tires prior so I wasn't really concerned about that.
Musicguy is offline
Old 12-07-2012, 09:39 AM
order the KYB's and change the struts asap, you'll be glad you did
Oldblue is offline
Old 12-07-2012, 02:47 PM
Doc brown's Avatar
If your struts are shot there is a good chance your control arm bushings are shot also, or are starting to wear. I believe that the reason the struts go prematurely bad is because of bad control arm bushings.
Doc brown is offline
Old 12-07-2012, 05:44 PM
Technical Moderator
All of those people that have never checked or changed their oil have been driving around on blown out struts for years. It is not a catastrophic failure.
donbrew is offline
Old 12-07-2012, 06:30 PM
THE BATMAN's Avatar
Leaking sluts ,
O-----
struts , Never mind.
THE BATMAN is offline
Old 12-08-2012, 01:16 AM
Very funny batman...
Ok so today I changed the 2 front
Struts to kyb great $ small labor cost.
Btw the mounts, bushings and end links
Looked like new! No wear after 50,000
Miles.
Jeff
Old 12-08-2012, 05:11 PM
Omnigear's Avatar
you should have went with fe5 struts from rockauto.
Omnigear is offline
Old 12-12-2012, 04:48 PM
let us know your input on the KYB's, I like mine
Oldblue is offline
Old 12-14-2012, 03:36 AM
Love my Kyb got them a little above cost use to be a 50% sponsor on my supra did not know about fe5's and my shop pushes kyb's shock & struts the tire shop was pushing monroe to me at triple the $ and i said hell no.
jeff
Quick Reply: leaking struts?
