Serpentine belt keeps falling
Old 05-17-2015, 07:25 PM
I wonder, if the crank pulley was left on the Malibu engine, and the A/C and the alt pulley are from the HHR, could it be that a smaller belt is required? Do you have the original HHR crank pulley to measure the diameter or the circumference to see if it matches the Malibu pulley?
I hope I got that correct.
Oldblue is online now
Old 05-18-2015, 05:57 AM
Lucky's Avatar
I did a little research a found aftermarket crank pulleys are the same from Malibu to hhr but if you look up a Delphi a/c compressor the Malibu is cs20063 and the hhr is cs10077.
I wonder if the a/c clutch is different?
So my question would be did you reuse the hhr a/c compressor for the install?
Lucky is offline
Old 05-18-2015, 09:33 AM
Technical Moderator
What about alternators? I have a feeling the Malibu would be different.
donbrew is offline
Old 05-18-2015, 05:41 PM
Lucky's Avatar
Good point. I looked that up and there are two different part numbers for hhr and Malibu
Lucky is offline
Old 05-19-2015, 10:38 AM
So then the alt pulley may be the culprit!
Old 05-19-2015, 04:27 PM
Mmgsxr750's Avatar
I'll Check on that, thanx guys
Mmgsxr750 is offline
Old 05-19-2015, 05:57 PM
Let us know !
Old 05-24-2015, 04:48 PM
Mmgsxr750's Avatar
Well fellas it turns out the ac compressor was missing 2 bolts, and it was starting to lean to the side. I guess the mechanic who did the engine swap didn't put all the bolts on. Just started running it today, hopefully this was the cause of the belt coming off, thanx for the help though guys
Old 05-24-2015, 09:38 PM
Lucky's Avatar
Glad to here you got it figured out. Sound like an easy repair.
Lucky is offline
Dwarf7az
Maintenance and Upkeep
10-11-2013 11:04 AM
Chevy_dork04
08-16-2013 02:09 PM
intofocuszx3
04-19-2013 08:07 PM
Timbo41
02-03-2013 10:39 AM
RICANBABY
07-28-2007 08:15 PM
Quick Reply: Serpentine belt keeps falling
