TTR solid engine mount install
Installed the TTR engine mount and transmission inserts a couple weeks ago. First few days had significant NVH while sitting still in drive. Now it only has rough vibes when cold, a little when leaving from a stop and when cruising just over 40mph with a little more than light throttle between 1800 and 2100 rpm. I like it and it has a much more conneted feel.
#26
Definetly nothing to do with sunroof vibration.
I have this mount and got no vibrations that matter, wheel has a little at cold start in the steering wheel but no one cares about that. Rotated mounts (I used stage 3 from ottp) cause rattle/vibration in the dash area which sucks but they are worth it. This year I may pull the dash and sound deaden it.
#27
Turbo Tech Racing motor mounts
These are totally worth the minor vibration! Not only can the lower your zero to 60 time, 1/8 mile, 1/4 mile times. They out last the original mount & save your Auto transmission. Love this motor mount it was easy to install and Off the line performance along with between shifts was instantly noticed. One of the better purchases I have made for my 2006 Chevy HHR LT2! I only give complements where complements are due. This part rocks!
