TTR solid engine mount install
Old 03-10-2015, 08:45 PM
Former Sponsor
TurboTechRacing's Avatar
More ready to ship.
TurboTechRacing is offline
Old 03-14-2015, 09:52 AM
Shadow1999's Avatar
Installed the TTR engine mount and transmission inserts a couple weeks ago. First few days had significant NVH while sitting still in drive. Now it only has rough vibes when cold, a little when leaving from a stop and when cruising just over 40mph with a little more than light throttle between 1800 and 2100 rpm. I like it and it has a much more conneted feel.
Shadow1999 is offline
Old 04-22-2015, 11:55 AM
Former Sponsor
Thanks!
Old 04-22-2015, 01:55 PM
Hallo
Will the solid engine mount cause my sunroof to vibrate a lot? when open at 25-35 MPH?
Boydie
Blue Beast (aka Boydie) is offline
Old 09-23-2015, 06:38 PM
Former Sponsor
No, you should only have minor vibrations when you are completely stop at idle. Minor at this also.
After you increase the RPM, the engine smooths out, and there are no vibrations.
Old 09-30-2015, 09:02 AM
  #26
breds2k's Avatar
Definetly nothing to do with sunroof vibration.
I have this mount and got no vibrations that matter, wheel has a little at cold start in the steering wheel but no one cares about that. Rotated mounts (I used stage 3 from ottp) cause rattle/vibration in the dash area which sucks but they are worth it. This year I may pull the dash and sound deaden it.
breds2k is offline
Old 06-28-2019, 10:42 PM
  #27
Deathwalker's Avatar
Turbo Tech Racing motor mounts
These are totally worth the minor vibration! Not only can the lower your zero to 60 time, 1/8 mile, 1/4 mile times. They out last the original mount & save your Auto transmission. Love this motor mount it was easy to install and Off the line performance along with between shifts was instantly noticed. One of the better purchases I have made for my 2006 Chevy HHR LT2! I only give complements where complements are due. This part rocks!
Deathwalker is offline
TurboTechRacing
01-14-2009 06:48 PM
Quick Reply: TTR solid engine mount install
