turbo install
turbo install
Got a turbo kit from a person that is or was on this site and got it installed and have started a trifecta tune, car idles fine but after car is warmed up the car dies when clutch is pushed in.
That's a really good question. But it creates more questions than answers for me......GDZHHR, Is the only one I remember that turbo'd one, send Him a pm maybe he still lurks in the background, and can give you a clue......
He is the one I got the stuff from and the last question I asked him he said he didn't know much about the build.
Any other symptoms? I can't see why it wouldn't stay running while the clutch is depressed.
So it idles fine, you push down the clutch and it dies? Is that correct? Any strange noises? I take it the "kit" came with it's own pre tuned ECM. Got any pics of the setup, or what you got with the kit.
I'll gladly help diagnose, just need some more details. I'm also confused by the seller. So he sold this to you but doesn't know much about the build? Was this a complete motor? Has it ever been run with the turbo setup. Sorry, I'm just making more questions for myself trying to understand.
In order to help understand here. You bought a turbo "kit" that he put together. Since the 2.4 didn't come with a turbo I'll since you're controlling it manually with BOV and wastegate.
It's a hahn's turbo kit, running 8-9 psi all engine components are stock. 60# injectors, factory ecu. If you look him up it's pretty easy to find his car
The automatic trans would have a big difference in tuning from a 5 speed.
There is a clutch pedal position sensor, I think. That probably shorts something, or sends a signal to the ECU? Just trying logic, since I don't know nothing.
I would question the tune. As donbrew suggested there is a clutch switch to contend with. Have you contacted trifecta ?
