Where to get a mount
https://www.chevyhhr.net/forums/deleted-threads-41/how-install-profit-custom-mount-967/Did you look into the How-to section. Check out this post.
Mine is mounted right on the dash, just another idea for you. I just bought a cell phone holder at pep boys. Since the photo was taken I now have moved the cord it runs up along the steering wheel, so only a little bit of the cable is out.
Originally Posted by GhstRider
Nice MP3 Player! You can watch movies and drive at the same time!!!
Thank you,
I have not loaded any movies or anything like that yet. Worried I might watch it and not the road.
Here's my sirius radio on an Equinox bracket. The bracket works great if you attach it through the lower radio mounting screw. I tried to use the upper radio mounting screw but the taper on the dash trim would not allow the bracket to be far enough away from the radio for the dash trim to sit flat. It took longer to route my antenna under the dash than it did to get the bracket in place. The thing that really makes this a clean install is using the eqiunox bracket and the mounting plate that came with the sirius radio. The mounting plate has screw holes that match up with holes on the bracket. I'm happy with it. Next up, hardwire power so it switches on and off with the radio.
I bought a Griffin Tuneflex for my iPod Nano off eBay. 18 bucks and it holds it out where I can see it and charges at the same time. It does require a cable, which I already had. Check'm out and see if you can get a deal. I know the one I bought was on average 45 bucks retail. Hope this helps!
http://search.ebay.com/_W0QQsassZa_amirzaQQhtZ-1
There are bunches of sellers and thousands of products on ebay!
