New head unit with nav. Installed
Old 10-01-2016, 02:38 PM
Lethal Tendencies's Avatar
I installed a new sound stream double din head unit with nav system and Bluetooth. Bought it from crutchfield . Crutchfield sets you up with everything you will need. The install was pretty easy. Crutchfield gives you the correct harness and info. Needed. You never have to cut any wires from the stock harness, so it will be easy to go back to the stock radio.
Lethal Tendencies is offline
Old 10-01-2016, 03:58 PM
Very cool! Did you have to carve out the back of the waterfall behind the radio?
Did you swap out door speakers?
Oldblue is offline
Old 10-01-2016, 04:30 PM
Nice clean looking install. Looks factory.
whopper is offline
Old 10-01-2016, 07:37 PM
No carving involved. Speakers will probably be next. The new unit is quite a bit louder than stock
Old 10-12-2016, 09:43 AM
MexicoTrucker's Avatar
Soundstream? No familiar with the brand.....
I need a unit that will utilize the factory XM unit and antenna. Any suggestions or is that even possible?
MexicoTrucker is offline
Old 10-12-2016, 02:03 PM
Crutchfield will have the necessary wire harness for that. You will have to find a head unit that has XM radio as an option. The unit I bought did not
Old 01-16-2017, 09:19 PM
Ls2_HHRss's Avatar
What double din dash kit is that. It looks factory. The metra and scoshe ones are a matte finish and doesn't look like this one.
Ls2_HHRss is offline
Old 01-16-2017, 09:26 PM
As he states he got it from Crutchfield
Oldblue is offline
Old 01-17-2017, 09:11 AM
That is correct. When I chose which receiver I wanted the crutchfield website will list optional items that are compatible with your car and the receiver you chose
Old 01-17-2017, 11:49 AM
It's that easy!
Oldblue is offline
Quick Reply: New head unit with nav. Installed
