OEM stereo part numbers.
Old 04-17-2008, 09:46 AM
06Daytona's Avatar
Question OEM stereo part numbers.
I'm interested in changing out my stock single disc player for a stock 6-disc player. I may even consider a single disc player with MP3 capability.
My problem is when viewing some of these that are available, I can't tell the difference as the single MP3 and 6-disc stereos look identical.
Does someone know the model # and/or part # associated with these units?
Thanks.
06Daytona is offline
Old 04-17-2008, 11:24 AM
ChevyMgr's Avatar
6 disc = 25780240
Single disc/MP3 = 25780239
ChevyMgr is offline
Old 04-17-2008, 11:44 AM
06Daytona's Avatar
Thanks, ChevyMgr!
Can I assume that the part #'s are the same for '06, '07 and '08?
Old 04-17-2008, 12:09 PM
ChevyMgr's Avatar
Originally Posted by 06Daytona
Thanks, ChevyMgr!
Both state 06-07. You can call Specmo which is where we order exchange units. Call 1-800-545-7910 and ask for Sales.
ChevyMgr is offline
Old 04-17-2008, 02:13 PM
One thing to remember is that after the switch, you will be required to have the radio "registered" to the car or it won't play. This requires a trip to the dealer.
GDZHHR is offline
Old 04-17-2008, 08:10 PM
BigBeefer's Avatar
Is there anything special in swapping a non-premium stock head unit out for a single disk MP3 head unit? Are the power/speaker/antenna connections all the same?
BigBeefer is offline
Old 04-18-2008, 06:35 AM
Doc brown's Avatar
Any reason you wouldn't consider an aftermarket system? Far cheaper and much better sound quality. If you're unsure what to look for, call http://www.crutchfield.com/ and tell them what you want. They'll be able to recommend something, and they provide the mounting kit for free along with installation diagrams to make the install a piece of cake.
Doc brown is offline
Old 04-18-2008, 07:16 AM
06Daytona's Avatar
Well, I'm looking at buying used, so it wouldn't necessarily be "cheaper". I prefer to keep things looking stock for now, but I would really like the feature of being able to play MP3 discs. I'm only looking to spend around $50 for a used one. I missed getting a 6-disc/MP3 unit a few weeks ago for ~$65 and I'm still kicking myself for that one.
Old 04-18-2008, 08:42 PM
BigBeefer's Avatar
Thats exactly my reasoning. I like the look of the stock unit, I just want the MP3 capabilities.
Old 04-22-2008, 07:59 AM
06Daytona's Avatar
I've found a couple of units that look like they are the higher end units as they don't have numbers for the radio selections, but the model numbers don't match those in the earlier post above.
One is 15832813
And the other is 15874061 as seen here...
ChevyMgr, can you help?
Quick Reply: OEM stereo part numbers.
