Stereo questions...
Old 03-17-2013, 06:19 PM
Ghost09's Avatar
Stereo questions...
Hey guys, I know this has probably been asked a lot, but my search only turned up vague info and a dead how-to link. I was wondering what the best way to pull the waterfall off is? I've read that i just need to pull the top or from the vents but i'm pulling so hard i'm afraid i will break the vents! Also what exactly do i need for an aftermarket double din deck? I have a 09' LS with the 6 speaker stereo.
I believe i need the GMOS-LAN 03 wiring harness ( Axxess GMOS-LAN-03) ,an antenna adapter (Metra Electronics 40-CR10) and a installation kit (Metra Electronics 95-3302). Does this sound right? Its mostly the wiring harness i'm having the hardest time with...
Thanks guys!
Ghost09 is offline
Old 03-17-2013, 06:37 PM
skyline26's Avatar
put ur fingers through the vents , just make sure when ur pulling it to make sure that you're grabbing the actual waterfall and not pulling on the vents.. then yes it will break
skyline26 is offline
Old 03-17-2013, 06:43 PM
badassbowtie's Avatar
I put a flat tip screw driver behind the plastic where the yellow arrows are below....came off fairly easily. You have to disconnect a few things if I recall correctly
badassbowtie is offline
Old 03-17-2013, 10:46 PM
Ghost09's Avatar
Awesome, thanks for the help! After i put a screw driver in the side it came out no problem!
Ghost09 is offline
Old 03-20-2013, 05:28 PM
Ghost09's Avatar
Does anyone know if all that is the correct harnesses etc?
Ghost09 is offline
Old 03-20-2013, 07:52 PM
I'm not an expert but my 09 needed the 04, think the difference is Onstar. The stereo shop install 2 of them that I have and they only worked a few minutes, they are both out on the shelf. They used a Pac11 adapter and I havent had any problem for 2 years.
SS fan is offline
Old 03-20-2013, 09:01 PM
Maxis Gamez's Avatar
Start from the bottom!!
Maxis Gamez is offline
Old 03-20-2013, 11:56 PM
Ghost09's Avatar
Thanks for the info! I was hoping to do this my self and save a few bucks but i think i'll just take it to a shop to be safe lol
Ghost09 is offline
Old 03-22-2013, 07:02 PM
hhrumadbruh's Avatar
Give me 5 minutes. I'll post a vid on how to do it. I've done it probably 50 times now...
**uploading video**
hhrumadbruh is offline
Old 03-22-2013, 07:14 PM
Ghost09's Avatar
Even better! LOL i learn better by seeing, but i'm sure lots of others would appreciate the vid!
Ghost09 is offline
Quick Reply: Stereo questions...
