REQUEST - Bluetooth add-on How-To section
I have a 2008 HHR SS with on-star and no UPF code. I did a search and read until my head hurts. Some people say it can not be done, some people say they bought a 2010 Cadillac STS bluetooth module, some say they upgraded to a 2009 radio and it works. Some went with a pioneer radio.
Can someone tell us exactly what our options are to install bluetooth in the 2006-2008 HHR and then put this write up in the HOW-TO section and set it as a sticky.
You mean like these aftermarket units from or friends at Carid?
https://www.carid.com/2006-chevy-hhr-bluetooth/
And this to adapt a Parrot Bluetooth to the HHR
http://www.crutchfield.com/p_120BT18...tooth&tp=61668
That's an awful small audience for a sticky.
But, I do seem to remember somebody went into more detail than I could follow.
IIRC, the bluetooth is part of the OnStar module. It is cellphone profile only.
Buying an after market radio equipped with BT is probably easier and cheaper.
I typed "bluetooth" into the search box and found these links among 1,077 others.
https://www.chevyhhr.net/forums/audi...2009-lt-31543/
https://www.chevyhhr.net/forums/audi...-module-46672/
https://www.chevyhhr.net/forums/gene...y-08-ls-39498/
• 2010-2011 Camaro LaCrosse SRX OEM GM 20842731 On Star Bluetooth Module
• Pioneer AVH-270BT Double DIN/BLUETOOTH USB AUX DVD Receiver $150
• GM 22740323 - https://www.christopherprice.net/how...llac-2847.html
• BlueStar - costartech.com - BlueSTAR
Here were a few options that I was looking at. I think I like adding the actual GM bluetooth module, this would by far be the cleanest install since it will operate exactly like the factory bluetooth in 2009 and up. I will do more research on this later and keep you guys posted.
Roesterman
03-12-2011 02:39 AM
