Eibach pro kit
Old 10-21-2016, 07:41 AM
Hhrfan23's Avatar
Eibach pro kit
Hi,
does anyone has a technical sheet on the eibach pro kit which includes e.g.
- permissible axle loads for the front spring version
- permissible axle loads for the rear spring version
I need that information to install the Eibach kit on my hhr which is registered in Germany.
To have my car checked by a technical supervisory association, which is a law in Germany if you do any changes to your car, I need an official information about the max. axle loads on the eibach pro kit (Partnumber 3899.140).
Please can someone here help me out?
I've already contacted Eibach in California to provide me with such info. Now I'm waiting for some feedback.
But maybe one of the forum members can help me too.
Thaks in advance and greetings from Berlin
HHRFan
Hhrfan23 is offline
Old 10-21-2016, 07:51 AM
Which spring kit are you asking about ? Posting the kit or part number would help in getting the correct specs.
Fwiw. You had another post asking about the German version of Eibachs. If that's the one you're looking for specs about, I doubt anyone here would have that info.
Your best bet is to get the specs from the manufacturer.
firemangeorge is offline
Old 10-21-2016, 07:59 AM
Hhrfan23's Avatar
I posted the Partnumber in my first thread, which is Eibach part#3899.140
USD$ 341.10
PRO-KIT Performance Springs (Set of 4 Springs)
# 3899.140
Front: 1.0 in
Rear: 1.6 in
More Info...
And yes, I am the one asking about the german version of the eibach kit. But since its discontinued I will have no chance to get it.
So I want to buy the US version and to have it build in my hhr the legal way I need to have the asked infos about axle loads to get the OK from the german technical supervisory association.
Thanks HHRFan
Hhrfan23 is offline
Old 10-21-2016, 08:08 AM
Technical Moderator
Eibach doesn't support it's products?
CONTACT US | EIBACH AMERICA
donbrew is offline
Old 10-21-2016, 08:14 AM
Hhrfan23's Avatar
I did 2 hours ago s i'll wait for response
thanks for your help
Hhrfan23 is offline
Old 10-21-2016, 08:20 AM
Sorry if I missed the part number in your 1st post.
This quote from your other thread has me confused.
"So i cannot just put in the us version of the kit, its illegal here."
You really should just wait till Eibach gives you the specs. Trying to get unofficial specs from some forum member isn't going to help you with the German inspection folks.
Old 10-29-2016, 05:52 PM
Hhrfan23's Avatar
So finally i hold a official Paper from eibach uk that confirms the permitted axle loads
Theres only one thing that confuses me.
The eibach pro Kit partnumber is 3899.140, but in the letter they Talk about partnumbers 3899.001 and 3899.002 can it be that these numbers actually written on the springs themselves? 3899.001 Front? 3899.002 rear?
Can some member please tell me the exact partnumbers which are written on each spring of the eibach pro Kit?
I have another Post asking alot of stuff about fe5 Parts, but since the eibach solution seems to work out for me id rather go for the eibach Kit because it will lower my hhr a bit more.
Tanks
Hhrfan
Hhrfan23 is offline
Old 10-31-2016, 12:02 PM
Hhrfan23's Avatar
Can someone please help and tell me which partnumber is printed on the front and rearsprings of the eibach pro kit. I know that the kit partnumber is 3899.140. But can it be that the numbers on the springs are 3899.001 and 3899.002?
I need to know before i order it from the us.
Help please.....
Hhrfan23 is offline
Old 10-31-2016, 01:23 PM
skyline26's Avatar
the whole kit is called 3899.140 but the front spring is .001 and rear spring is .002
installation page
http://www.catalograck.com/imgvd/eib/d2430.pdf
skyline26 is offline
Old 10-31-2016, 01:31 PM
Hhrfan23's Avatar
Skyline,
Thanks for the quick reply. Thats what i needed cause now i finally can order the kit and install them on my hhr.
Now i will get permission from the technical supervisory association to use the kit on my car. Finally. Ill post pictures after all work is done.
Thanks again....
Hhrfan23 is offline
Quick Reply: Eibach pro kit
