Grinding noise from brakes?
Old 10-25-2014, 07:34 AM
DeCaff2007's Avatar
Hello all. I'm brand new to this HHR thing. It's actually my fathers car. 09 HHR LS. 2.2L (I'm guessing that's the norm).
So one day we were driving along and the front end starts shaking violently when the brakes are applied. Obviously warped rotors. It got so bad on that one trip that we had to change the pads and rotors for brand new ones right there in the Advance Auto parking lot.
So that solved the problem.... but now fast forward a few weeks. Hit the brakes and there is a grinding noise from what seems like the right front.
Now, these pads/rotors are brand spanking new, but I still removed and inspected them. They look pristine, and so does everything else around that area.
I see no leaks, no evidence of anything where it shouldn't be, and I've checked everything I know to check. Still.... there's a persistent grinding when the brake pedal is pressed.
I've searched the forums, Googled, I even looked for recall info. Nothing!
Anyone have any suggestions?
DeCaff2007 is offline
Old 10-25-2014, 09:25 AM
Technical Moderator
Hubs, probably was the original shimmy too.
donbrew is offline
Old 10-25-2014, 12:22 PM
X2 on the hubs, HHR's are known for having less than durable hubs.
Here's a "How To" on changing them out, just click on the link below...
https://www.chevyhhr.net/forums/how-...acement-38946/
P.S. aboard!
843de is offline
Old 10-25-2014, 01:04 PM
Welcome to the site, X3 on the hubs! And double check those rear brakes the drum type have to have the shoes adjusted every 5,000 miles or so !
Oldblue is offline
Old 10-25-2014, 08:24 PM
Technical Moderator
"I've searched the forums, Googled, I even looked for recall info. Nothing!"
Real strange; I typed "grinding noise" into the SEARCH box and got 10 PAGES of results, most of the first page related to hubs.
donbrew is offline
Old 10-25-2014, 08:40 PM
DeCaff2007's Avatar
Yeah those are google results, not forum topics.
Alright well I'll check the hubs again but they both seem rock solid.
Old 10-25-2014, 11:25 PM
They can seem "solid" but still be failing internally. You could get your hands on a dial indicator and check for excessive runout, but pay attention to the noise as you drive.
If it increases and decreases in intensity with speed, or if the noise increases as you "load" a corner of the vehicle in a turn, then you're almost certainly dealing with a bad hub.
843de is offline
Doc brown
07-21-2017 05:33 PM
michael mueller
08-13-2014 06:07 AM
colzdad
03-22-2014 06:46 PM
mynameistaken
11-01-2010 01:13 PM
Eldon
08-09-2009 07:06 PM
Quick Reply: Grinding noise from brakes?
