hhr front strut replacement
Old 06-10-2014, 09:57 PM
gvander's Avatar
Replaced suspected bad strut on my HHr, front left. Also the sway bar link. Ended up with a much worse noise than before. Very noticable clunk when going over speed bumps etc. Everything is torqued to specs, but obvious clunking over driveway curb etc. Any ideas ?
gvander is offline
Old 06-10-2014, 10:51 PM
Did you replace the upper strut mount, they fail over time as the grease dries up, the standard symptoms fit your description.
843de is offline
Old 06-11-2014, 01:26 AM
Like brake pads, when replacing struts or shocks, you really need to replace them in pairs (not just one side).
whopper is offline
Old 06-11-2014, 06:19 AM
Technical Moderator
Lower control arms, sway bar BUSHINGS.
donbrew is offline
Old 06-11-2014, 04:57 PM
Doc brown's Avatar
X2. My theory is that the LCBs go then cause excessive wear on the struts.
Doc brown is offline
SC_HHR
08-11-2013 09:05 PM
09 Silver Bullett
7
04-01-2013 08:14 AM
Scrivs
12
03-25-2010 08:39 AM
robado
10-27-2006 12:47 AM
Quick Reply: hhr front strut replacement
