Lower Control Arm Bushing?
Max are you saying you have an air wrench gun , but no air hammer/ chisel?
You will need at least a bench vise to press out the old bushings and press in the new.
Then there will be the ball joint to drill out the rivets to replace those.
For the cost and effort buy complete new LCAs , then you only have to R&R the 4 bolts
Somebody posted a YouTube doing the job yesterday in another thread.
"Lower control arm" in the search gave 10 pages of results. I bet there are a lot of different suggestions on how to do it in them.
I think you have some sound advice there young man.
Thanks a bunch for that. I feel 10 IQ points dumber now.
Like a BOSS.
#26
Mine looked like the rear bushing in the Saturn video, I did the bench vise and sockets dance like in the Blue on Blue video ( Mom was a big Bobby Vinton fan! ) and my ball joints were tight at that time but 3 months and a pothole or two later! I had to drill out those six rivets and install Moog ball joints which of course required removing those LCA's again! So, now when a friend needs their bushing or ball joints done I tell to order up LCA's and be done with it! Let them learn from my mistakes!
#27
i have to agree that just geting new LCA's would be the best way to go. i had a tough time getting the moog vertical bushings into the stock aluminum arms with a (big) bench vise....the front horizontal bushings on the arms were ok.....as were the ball joints. either way, spending the dough on replacement LCA's would be the way to go....you indicated that you've got an FE1 suspension......i think that those LCA's are steel.......check the rockauto.com listing...
#28
Just did mine. One hour per side.
Half way through wrestling the second ball joint I slapped my forehead and wondered why not just loosen the three nuts holding the top strut mount.
#30
Well it's been discussed, even in this thread I believe.
The stamped metal ones belong on Cobalts, but work on HHRs. The FE5 has a different ball joint and possibly different rubber bushings. All HHRs came out of the factory with aluminum allow arms.
I know of no arguments for or against the stamped steel version, other than that's not came on it.
red2008
10
05-10-2014 05:32 AM
working on it
04-23-2012 08:08 PM
QuickRick
22
02-27-2010 01:56 AM
