jack it up
Old 09-18-2014, 10:32 AM
ricejeep's Avatar
jack it up
I need to raise my 2008 up to get in my garage. Builder made driveway too step, must back in now. I need 1" lift for clearance to drive in. Anybody have the 'how to' for this?
ricejeep is offline
Old 09-18-2014, 11:28 AM
LawDog88's Avatar
Post #2 HERE may be of help.
LawDog88 is offline
Old 09-21-2014, 05:17 PM
mrarff's Avatar
Most parts stores carry coil spring spacers that are made of rubber. I put 2 on each spring and held them in using zip ties. Just put the car on lift (so the spring is completely relaxed), stick them in between the coils, and use zip ties to hold them in place.
mrarff is offline
Old 11-17-2014, 01:06 PM
scbill's Avatar
ricejeep, If you haven't bought parts yet, you could try putting a treated timber..2"X12" the width of the wheels, put it so the wheels cross it just before the car contacts the floor. Had the same problem with the underside dragging on a too steep ramp. If you could locate a couple of scrap pieces of timber to try before you purchase the full size. I it works OK, secure it with anchors.
scbill is offline
Old 11-17-2014, 01:16 PM
LawDog88's Avatar
Hockey Pucks also work well...
LawDog88 is offline
Old 11-17-2014, 01:26 PM
What's a hockey puck ?
firemangeorge is offline
Old 11-17-2014, 01:52 PM
A: Little round things that folks in cold climates whack back and forth with sticks while they're on skates, attempting to make "Goals" when the little round things get past a person dressed in a padded outfit who gaurds the net.
It seems that whacking the little round things makes people very angry, because the hockey "players" also seem to be amatuer boxers.
We have a hockey team in Charlotte for displaced Northerners who miss whacking things with sticks in the Winter.
843de is offline
Old 11-17-2014, 05:08 PM
Snoopy's Avatar
Not exactly sure WHERE you are speaking of. Are you saying the driveway to the street OR the driveway to the garage?
Snoopy is offline
Old 12-29-2014, 08:55 AM
ricejeep's Avatar
Thanks
Thanks for all the feedback. The coil spacers sound like the easiest and least expensive option to try. Will this put additional strain on the front drive angle?
ricejeep is offline
Old 12-29-2014, 10:30 AM
Not enough to worry about. :)
whopper is offline
Quick Reply: jack it up
