Replacing Front Stabilizer Shaft Bushings - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 10-14-2012, 09:45 AM   #1
How do you replace Front stalizer shaft bushings? I had new greaseable bushings put in about 6 months ago and now they are loose. Thanks for any help.
SteveMaine is offline   Reply With Quote
Old 10-14-2012, 07:11 PM   #2
are you saying that the bar's loose inside the bushings..?? if so, the attachment brackets may have loosened up. cant see the urethane bushings beating themselves out......especially if they were kept greased.....i've heard of the brackets becoming loose in some instances.....
alexrckid is offline   Reply With Quote
Old 10-18-2012, 10:25 AM   #3
Steve, check about 4 topics lower on the page. There is a big topic about replacing the sway bar bushings. From replies I have read in here, the poly bushings are too big to begin with. They are 1", which is 25.4 mm. The front bar on a non SS is 25mm. Not 25.4mm. I got the correct OEM bushings at the dealer for about $4 a piece. They are very easy to replace. I think it took me under 45 minutes to do both.
Here you go.
Replacing Sway Bar Bushings
loweredd is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Replacing Sway Bar Bushings kmcrae476 Brakes | Suspension | Shocks | Struts 34 03-18-2016 08:17 AM
replacing lower control arms/bushings R CA HHR Problems/Service/Repairs 12 12-03-2013 08:36 PM
Replacing Stabilizer bar bushings diskullman General HHR 2 06-01-2011 01:00 PM
Stabilizer Bushings 07 HHR joeg.satx Problems/Service/Repairs 18 01-23-2011 12:54 AM
SS Front stabilizer shaft links ? Bad at 15,000 miles? THE BATMAN Problems/Service/Repairs 13 02-09-2009 07:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
