Steering and suspension
I had a mechanic change the struts on the front of my HHR and know the front end is out of alignment and the passenger tire is wearing on the outside only. I am taking it to Chevrolet and have them check the entire front end and also check my steering column for a weird noise that only happens when I make a turn. My HHR only has 36000 miles on it. It's a 2006.
Changing struts out should not affect the alignment. Either there was an installation error or the wrong struts were used.
Why take it to the high priced dealer ? Either back to that mechanic to fix his possible mistake or find a new repair shop.
As one of our mods likes to say. "Those techs at the dealer went to the same schools as the independent shop techs."
X4,..... Unless somebody has installed camber "cam bolts".
One tire wearing oddly points to LCA bushing or camber. Toe would affect both sides (toe is the only adjustment there is in a stock HHR).
A mechanic change the struts on the front
(and now) the front end is out of alignment
Changing front struts will not make you go out of alignment.
If your right side wears that much did you already have an issue?
Did you "smack" something before the repair?
Bending the lower control arm inward can cause the tire wear.
Did/does the car pull to the right?
I had an alignment a year ago and they said everything was fine, I started to get that dreaded brake judder, even after I had upgraded to larger SS min Brembo front brakes.
I replaced the lower control arm bushings with the Moog K200792 bearings, the steering wheel was now off to the right and the left front tire was scrubbing the inside side out the thread, back to the alignment rack, and the toe was exactly the wrong direction as it was adjusted two weeks before, my alignment guy apologized for not catching the lower control arm bushing being spongy and one was torn apart.
The bushing looked fine in the car but fell apart after removing them.
brazor06
12-11-2022 07:59 AM
anthony303
10-25-2018 10:35 PM
donbrew
12-26-2014 09:00 PM
JMichael
10-23-2012 05:19 PM
RStruthers
07-07-2012 10:50 AM
