Torque Specs for Brake Caliper Bolts
TomR00 needed some more brake specs, so I posted this in another thread.
I thought I would post it here too.
Fastener Tightening Specifications
Application Specification--------------------------------------Metric-- English
Brake Caliper Bleeder Valve - Front (J41, JL9, JM4)-----11 N•m-- 97 lb in
Brake Caliper Bleeder Valve - Rear (JL9)------------------11 N•m-- 97 lb in
Brake Caliper Bracket Bolt - Front (J41, JM4)-------------115 N•m-- 85 lb ft
Brake Caliper Bracket Bolt - Front (JL9)-------------------130 N•m-- 96 lb ft
Brake Caliper Bracket Bolt - Rear (JL9)--------------------115 N•m-- 85 lb ft
Brake Caliper Guide Pin Bolt - Front (J41, JL9, JM4)-----35 N•m-- 26 lb ft
Brake Caliper Guide Pin Bolt - Rear (JL9)------------------35 N•m-- 26 lb ft
Brake Hose Fitting Bolt - Front and Rear------------------40 N•m-- 30 lb ft
Look on your RPO list in the glove box to determine which spec to use.
Yes, if you replace the rotors and brake pads, you must torque the mounting bolts of the caliper mount and the caliper to mount bolts properly. If not, you could over torque them and break one off, or under torque them and have them come loose, causing a loss of braking and damage to the caliper and wheel assemblies.
Edit: I just put my EBC rotors and brake pads on last Sat., I'm going to run them a week and go back and recheck the bolt torque again this Sat. just to be on the safe side.
TomR
TomR
