wheel bearing/hub assembly spacer
to the forum dudley!
The wheel bearing hub spacer(or as GM refers to it...SHIELD. Brake Flange Plate), is there to provide the proper clearance between the flange on the hub, and the steering knuckle. If you're replacing your front hubs, its important to replace the spacer in the same orientation as it was removed.
Also its important to tighten the knuckle to hub bolts to 115 N·m (85 lb ft), and axle shaft nut to 110 N·m (81 lb ft).
It also supposedly deflects water, especially on the TSB affected models. That is the reason for the "comb over" I think.
What does Chief Inspector Clouseau think "gardiner" means? Isn't it spelled different in French? "Jardinier" or somethin'?
jeffros hhr
10-10-2019 08:35 PM
jbiesent
44
05-09-2016 12:11 PM
jezmo
7
07-03-2014 11:52 PM
babeba67
Maintenance and Upkeep
02-01-2014 09:21 PM
