Wheel Studs
Old 06-30-2008, 06:09 PM
Ratzilla's Avatar
Wheel Studs
I am trying to find out the specifications on the wheel studs of our 2007 HHR. (we have broke 2)
It looks like the same stud that is used on a the S-10 Blazer, a 610-254 / M12 x 1.5 x 40
Does anyone know for sure, or where I can find out.
Thanks Marshall
Ratzilla is offline
Old 07-12-2008, 11:28 AM
Hib Halverson's Avatar
If you are breaking wheel studs, you're either overtightening the wheel nuts or you have some type of wheel/tire package which is way overloading the studs and the hub.
I'd fix those issues first before I'd go looking for wheel stud specs.
In fact, if you have one of the two problems listed above and you've broken two studs already, I'd replace all 20 of them.
The torque specs for wheel nuts are in the FSM but, typically, I use 80-100 ft.lbs and I use an accurate, dial-indicating torque wrench for that purpose.
Lastly, many "click" type torque wrenches can be inaccurate. If that's what you use and you have not had it checked in a couple of years, that could be your problem, especially if it's a low-cost or foreign-made tool.
Hib Halverson is offline
mike321
Tires & Wheels
33
02-06-2012 11:51 PM
andoll83
12-15-2009 05:33 PM
traketo
10
09-08-2009 09:11 PM
Ratzilla
07-02-2008 07:08 AM
Quick Reply: Wheel Studs
