automatic cooling line seals
Old 01-04-2016, 11:56 AM
RF2
RF2's Avatar
Has any one changed the seals for the cooling lines on the transmission end? It would be item #4.
I have leaking cooling lines at the steel to rubber crimp and at 220K thought it would be a good idea to change every thing at this time.
RF2 is offline
Old 01-04-2016, 02:36 PM
Lucky's Avatar
I think oldblue replaced his trans cooler lines. I'm sure he will get on here later.
Here is one thread that may help. https://www.chevyhhr.net/forums/prob...r-lines-52608/
Lucky is offline
Old 01-04-2016, 04:45 PM
I did change the lines and those seals. It's not a fun job!!
Oldblue is online now
Old 01-04-2016, 05:31 PM
Dbeluscak's Avatar
I was gonna say... I bet they aren't to fond of being removed! Never had to yet. If you dig in, try and get some pics for us!
Good luck
- In all my rebuilding over the summer, I managed to lose Item #7 on Grandmas HHR. Right now the lines are held in place with .030" solid core welding wire. Which works, and doesn't leak but if you could provide a part# for those I'd be much obliged!
Dbeluscak is offline
Old 01-04-2016, 05:58 PM
That clip shows to be GM part # 24205103. $9 for that little thing !
2008 Chevrolet HHR Hatchback AUTOMATIC TRANSMISSION OIL COOLER PIPES
firemangeorge is offline
Old 01-04-2016, 07:34 PM
Dbeluscak's Avatar
Thanks George, for $18 and shipping I think I'll keep my welding wire in there!
Old 01-05-2016, 03:16 PM
Technical Moderator
Go to NAPA or any other AP store they have sampler packs of those clips for a couple of $. Try the "HELP" section.
donbrew is offline
Old 01-07-2016, 09:42 AM
RF2
RF2's Avatar
Gee, That was fun. The fittings in the radiator were easy. Getting the cooling lines out then back in wasn't too bad. Replacing the trans seals
Now on to the next project.
RF2 is offline
Oldblue
Drivetrain (Excluding Engine)
53
11-23-2020 07:46 PM
windsmith
10-19-2010 10:58 AM
Lone Ranger
07-14-2007 03:40 PM
txsman2930
06-26-2006 08:18 AM
Quick Reply: automatic cooling line seals
