SS automatic axles - Chevy HHR Network
Commonly Used Part Numbers A place to post commonly used OEM part numbers needed for routine maintenance and replacement parts.
Reply
Thread Tools Search this Thread
Old 06-06-2016, 12:25 PM   #1
Technical Moderator
Images: 70
SS automatic axles
jrbarajas2008 says that the correct part number for SS axles (auto) is gm8206.
I GoOgled the number and several sources popped up.
donbrew is offline   Reply With Quote
Old 06-06-2016, 03:34 PM   #2
Images: 106
But every one of those sources say it will NOT fit. Sooooo.....
But none of them asked what transmission.
RJ_RS_SS_350 is offline   Reply With Quote
Old 06-06-2016, 04:44 PM   #3
Technical Moderator
Images: 70
jrbarajas2008 says he has them on his 2008 SS. I did ask him if he had installed them.
Carid says they fit G6 with the same auto trans. And Malibu with 4 speed (doesn't say auto or manual).
Rockauto says the fit most every other 4T45-e car.
I did once buy a set of off brand axles that "fit", only problem was the boots did not have the correct number of ridges and they split very quickly.
Old 06-06-2016, 06:13 PM   #4
2005HHRauto's Avatar
Images: 165
I found a really good site that goes into better detail on GM parts, & what they fit.
The "Product Fitment/Applications" section on this part seaching site shows ALL GM models that a part fits.
The Product Application Notes of the Product Assemblies section shows exactly what the part fits.
DON'T pay attention to the product description under this Product Assemblies info as it is just general/generic info...
It looks like the shaft for an auto SS doesn't fit any other car in the GM lineup.
Get them while you can, as it's very special...
SHAFT. Front Wheel Drive Axle. DRIVE SHAFT/FRONT WHEEL; SUSPENSION/FRONT made by GM. #15938134
Same deal with standard front calipers on our HHR SS
They don't fit ANY other GM cars.
CALIPER. Wheel Brake Cylinder/Caliper. BRAKE CALIPER/FRONT for Chevrolet HHR (2008 - 2010). #25894356
CALIPER. Wheel Brake Cylinder/Caliper. BRAKE CALIPER/FRONT for Chevrolet HHR (2008 - 2010). #25894355
ACDELCO = 172-2482 left & 72-2483 right
You will NEVER get the correct reman calipers, so don't even try.
There are so few of these, as the caliper piston size is special...
The in tank fuel pump is also unique & fits only HHR SS
http://www.wholesalegmpartsonline.co.../19207956.html
There are so many other one-of-a-kind unique parts that only fit our HHR SS.
When they're gone, that's it, & if you need it you're SOL
2005HHRauto is offline   Reply With Quote
Old 06-06-2016, 07:18 PM   #5
Site Vendor
Images: 191
So then I shouldn't attempt taking the SS calipers apart to powder coat? I was hoping I could pop the piston and rebuild. Looks more like reuse.
And that's no Bueno on the axles. I'm guessing I'm going to need some at some point. We have no intentions on giving up our SS.
Dbeluscak is offline   Reply With Quote
Old 06-07-2016, 12:56 PM   #6
Images: 165
You can still get the pistons & rebuild kits.
HHR SS piston = 55mm, vs standard piston = 60mm , (may not be the exact numbers).
I use Centric parts.
front rebuild kit = 143.91016
rear rebuild kit = 143.62043
Centric front caliper piston for HHR SS = 146.54064
Centric rear caliper piston for HHR SS = 146.38038
Today I finally bit-the-bullet & ordered a spare half-shaft,
just in case, as I may need one someday, as I run with slicks at the track.
This part is on national back order, & i just hope that they will build more.
If this part does get cancelled, because GM decided that it's not worth it to build them anymore,
I can take my broken one to a good local driveshaft shop to be rebuild, it will mean 'downtime', with my 'buggy' on 'jack-stands' ,
waiting probaby a week for the repaired unit.
Been there, done that, with other car, & don't want to do that again.
Old 06-08-2016, 08:13 AM   #7
DrLoch's Avatar
Images: 41
Check here The Driveshaft Shop | Cobalt - Chevrolet - Domestic Axles
DrLoch is offline   Reply With Quote
Old 06-08-2016, 09:45 AM   #8
Images: 165
Quote:
Originally Posted by DrLoch View Post
Thanks for the link...
They would be 'last' resort, as at more than twice the cost of OEM, these stronger units aren't really needed for our 'buggys', unless all out racecar. They don't show automatic axles as a 'stock' item, but I'm sure that they will custom built them for anyone. I'll stick with my local 'driveshaft' shop if I need to get one rebuilt. But, if my spare OEM one that I have on order, doesn't happen if GM discontinues building these, I will seriously think about ordering one of these for a spare.
decisions decisions...
Old 06-08-2016, 10:16 AM   #9
Images: 20
Oldblue is offline   Reply With Quote
Old 06-08-2016, 10:35 AM   #10
Images: 165
Not true...
Quote:
Originally Posted by Oldblue View Post
They buy their axles from The Driveshaft Shop...
Reply
Thread Thread Starter Forum Replies Last Post
LSJ Axles on a 2.2L ? lunchbox 2.2L Performance Tech 3 10-29-2011 08:55 PM
LSJ Axles lunchbox General HHR 0 05-27-2011 09:35 AM
2006 hhr axles keep wearing out TONY SCALO Problems/Service/Repairs 7 05-03-2011 08:23 AM
Hhr/ss cv axles gcsd3742 SS Specific Service Issues/Repairs 6 08-24-2010 08:26 AM
axles replaced ChevyM84 Problems/Service/Repairs 4 02-03-2009 04:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
