SS axles+brake calipers+fuel pump
Good find Randy
Should make this a sticky.
Just for laugh's took the auto p/n and I found this on Wally World
https://www.walmart.com/ip/First-Equ...22227055879817
Good find Randy
EDIT: This is a little troubling, for manual trans: GM says right and left are different.
Left 20778307
Right 20778308
DRIVE SHAFT/FRONT WHEEL
I wonder why all the aftermarket only give one number, not side-specific.
Technical Moderator
The difference is a good 3 inches. Auto have the same because they have an internal extension on one side.
I had thought the difference in the LT and the SS shafts was the number of splines?
The GM part numbers, on Amazon, says they fit. Also there is a review on each, from the same buyer, that they fit. Amazon shows a difference in length of 6.5"!! Granted, that isn't precise, but shows that they are indeed different lengths, like don said.
So either W0133-1835283 doesn't fit at all, or it's only for one side, and we don't know which. So we're back to GM only again.
Might call into question the accuracy of the fitment for the auto axles as well. If anyone orders, get a fitment guarantee from the seller!
