40 mph RPM bounce
Old 07-23-2016, 09:59 AM
DW I read your post that your 2009 2.2 auto has demonstrated these issues It could be the 2.4 has VVT and the 2.2 doesn't, at least my 2007 2.2 doesn't.
Does you 09 2.2 have VVT??
It could be the program in the TCM is different from 2.2 to 2.4.
I see that bikerboy89, the OP has an '08 2.2 automatic.
Oldblue is offline
Old 07-23-2016, 10:41 AM
Technical Moderator
2009 2.2L should be VVT, unless they snuck a mid-year change in, 2009 was supposed to be the first of VVT in the 2.2L.
donbrew is offline
Old 07-23-2016, 10:58 AM
I thought so but wanted to be sure, if DW's 2009 has VVT then it's the 2.2 TCM program and nothing to do with VVT equipped HHR's , I've never seen a complaint about this from an automatic SS owner for instance, or 2.4 automatic owner.
Oldblue is offline
Old 07-23-2016, 11:27 AM
DwRed2LT's Avatar
Maybe thats it Oldblue as i have been happy
as can be with my '11s trans cept for losing
the reverse band.
DwRed2LT is offline
Old 07-23-2016, 11:29 AM
But does your 09 have VVT?
Oldblue is offline
Old 07-23-2016, 11:38 AM
  #26
DwRed2LT's Avatar
I really dont know Oldblue.
2.2 with auto is all i can tell you
DwRed2LT is offline
Old 07-23-2016, 11:49 AM
  #27
Have a look at the valley in the valve cover, if it has the two solenoids on the passengers side of #1 cylinder then it has VVT, the intake side of the valve cover maybe embossed Ecotec VVT also. I'm asking you to run out today but maybe next time you check your oil?
I'm like a coonhound on a scent , but it's a little hot out today for that!
Oldblue is offline
Old 07-23-2016, 11:54 AM
  #28
DwRed2LT's Avatar
Its only 32C that feels like 38C or 89F and 99F
DwRed2LT is offline
Old 07-23-2016, 11:59 AM
  #29
It's 36 here! C that is 96.8, I'm taking my stick and gonna lie in the shade! or on the couch in the air conditioning!!
Oldblue is offline
Old 07-23-2016, 12:05 PM
  #30
DwRed2LT's Avatar
bingo bongo. . . .intake side is. . . embossed
Ecotec
VVT . . . . . . . .now imma off to find a cold shower.
actually its not that bad if you get out of the sun and catch a breeze.
DwRed2LT is offline
Quick Reply: 40 mph RPM bounce
