Auto tranny leak
Old 06-24-2014, 08:45 AM
Bigpatshhr's Avatar
Auto tranny leak
It's leaking slowly right where the tranny lines go into the transmission. I see #2 listed and see the nut to remove the small manifold, is there a gasket kit or oring there I can replace? Thanks for any help
Bigpatshhr is offline
Old 06-24-2014, 09:48 AM
Technical Moderator
Seems that #4 in the pic is the seals?
donbrew is offline
Old 06-24-2014, 12:11 PM
Bigpatshhr's Avatar
Yeah I believe so wasn't sure what I was looking at, at first. Dealer said it's common and a $12 part.
Old 06-24-2014, 03:19 PM
Part #4 there are two, replace both of them!
Oldblue is offline
Old 06-24-2014, 03:25 PM
Bigpatshhr's Avatar
Thank you for that. I will.
Old 06-24-2014, 03:29 PM
I did the lower one, and had to do the top one three weeks later, so while you're at it!! get dirty once!
Oldblue is offline
asanti
10
10-14-2011 07:47 AM
herosbug
10-27-2010 01:33 AM
JJ's BLACK SS
05-29-2009 11:06 PM
JP Duke
04-19-2009 11:05 PM
m0rie
03-13-2006 08:20 PM
Quick Reply: Auto tranny leak
