trans axle output shaft seal replacement
Don't over think. How would the sleeve wear out? The metal is much harder than the rubber seal that it rubs on.
Go ahead and do it if you want to, but I see no reason to. I might replace the circlip, depends on my mood at the time (I never have).
It took a few minutes, but here:
hhr output shaft seal | eBay
Did you break the plastic inner part of the bushing when you replaced the shaft?
novadude
Drivetrain (Excluding Engine)
7
08-31-2013 04:31 PM
2007HHRLT
08-22-2012 10:36 PM
