Trans Flush
Old 09-21-2014, 03:54 PM
jarheadbobandmax's Avatar
Trans Flush
I have an 08 LT panel with an automatic trans which I understand is sealed, at what mileage is it recommended to take it to the dealer to be flushed and a new filter if that applies?
jarheadbobandmax is offline
Old 09-21-2014, 04:28 PM
Technical Moderator
Please use the search and your owners manual.
Search "owners manual" or
" transmission flush"
donbrew is offline
Old 09-21-2014, 04:50 PM
Plus. Why would you think it has to go to the "dealer" ? A good independent shop would most likely be less costly.
firemangeorge is offline
Old 09-22-2014, 10:52 AM
Twistedtat's Avatar
I did mine myself at 150,000 miles. All you need is jack stands and a couple sockets. Plus a helper for checking the fluid after you fill it.
Twistedtat is offline
Old 09-22-2014, 11:40 AM
Knightrider03m's Avatar
Per the owners manual, never.
Knightrider03m is offline
Old 09-22-2014, 11:56 AM
isaacm66's Avatar
I just got mine done at the dealer when i reached 100k. I tried taking it to two other places and they did not want to touch it. The excuse they gave me was that when "shops" do the transmission flush they only flush out about 60% of the fluid and since it has 100K miles they advised the dealer would do a 100% flush. Not sure what the process was but they flush out ALL the fluid and clean some screen that they advised doesnt get replaced just clean
When i went to the dealer they told me the same thing that they go through a process that pushes out all the fluid and other shops wouldnt do it. Shops don't tell you they only empty out 60%
isaacm66 is offline
Old 09-22-2014, 12:30 PM
Twistedtat's Avatar
I asked my local dealer about this process. The screen they are talking about is the transmission filter. The dealer stated that they use the machine to suck out all the fluid, and it cleans the filter. They also stated they do not drop the trans pan either. So how are they going to change the filter if they do not drop the pan? They had no answer.
Old 09-22-2014, 02:08 PM
If you think that dealers have some special "magic" that the independent shops don't have, then you folks are sadly mistaken.
Any good independent shop that has a flush machine will do the same service that the dealer would.
As far as "the flush will clean the filter", well that's just a bunch of saleman bull****.
Old 09-22-2014, 05:02 PM
Technical Moderator
BG, Snap-On, every tool company with truck sales.
Any shop that doesn't have a machine is a friend of mine. They charge a lower hourly rate usually. Somebody has to pay for the magic machines.
They also sell power steering flush machines and engine flush machines.
Interestingly enough GM put out a TSB AGAINST using any of those flush machines, but dealer service departments have to make a buck so they ignore it.
But still, why not just use the search tool and read all of the other identical threads?
Like this: https://www.chevyhhr.net/forums/main...-change-32272/
and this: https://www.chevyhhr.net/forums/main...d-flush-11640/
and this:https://www.chevyhhr.net/forums/driv...ion-pan-39975/
and this: https://www.chevyhhr.net/forums/prob...ck-2-2-a-8639/
and this: https://www.chevyhhr.net/forums/main...ge-easy-46849/
and 50 or so more.
donbrew is offline
Sister's HHR
07-20-2015 12:11 AM
hhrumadbruh
21
06-15-2014 06:43 AM
tanker36
Maintenance and Upkeep
04-05-2013 10:58 AM
hhrlover101
11
11-22-2012 08:41 PM
jima59
02-03-2012 11:27 PM
Quick Reply: Trans Flush
