Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Better Air Intake Setup?
Old 07-31-2013, 02:32 PM
prod's Avatar
Our cars are very picky on maf location. Even well known manufacturers had problems. Good luck
prod is offline
Old 07-31-2013, 04:19 PM
jay loukakis's Avatar
The pipes are tooo big and you are getting all of the engine heat. very little cool air to the engine.
jay loukakis is offline
Old 07-31-2013, 04:22 PM
skyline26's Avatar
ya this seems to be just like the cgs intake x2 now
skyline26 is offline
Old 07-31-2013, 04:24 PM
And 3 inch instead of 2 1/2 inch so no velocity of air flow.
Old 08-01-2013, 08:11 AM
SpaceCowboy's Avatar
these cars are setup perfect for a hood air intake...surprised but then again not that they don't make one
SpaceCowboy is offline
Old 08-01-2013, 07:35 PM
prod's Avatar
After the sc I'm hoping to do a functional cowl hood feeding a modified airaid intake. Id prefer finding a donor hood first though.
prod is offline
Old 08-01-2013, 09:28 PM
IgottaWoody's Avatar
Dont think cowl will work very well because of the aerodynamics....scoop does....there were discussions here on that. The way the air flows over the hood does not create the high pressure area like other vehicles....
IgottaWoody is offline
Old 08-01-2013, 10:28 PM
prod's Avatar
Just doin it for fun and to hear the supercharger better.
For it to improve performance it would be huge, big enough to suck air off the windshield. This ain't no top fuel drag car.
prod is offline
Old 08-03-2013, 08:44 AM
tracy waddell's Avatar
Boydie, I just saw this thread and it's just like Jay said,your pipe dia. is to big. I've made about 6 different air-intakes to see what would work and what wouldn't. Different diamenter pipes, lengths and different filters.I would suggest plugging up where you first put the MAF sensor. And re-locate it where both tubes come together. But I really think the 3" dia. tube is too big. It's a hit and miss with experimenting with the air-intakes on these computer assisted engines.
tracy waddell is offline
Old 08-04-2013, 10:18 AM
Tracy
As stated in a previous post I intend to move the MAF sensor closer to the original location and see if that works. I don't really believe the difference between 2 1/2 and 3 inches pipe diameter should make much of a difference but we will see.
Boydie
Blue Beast (aka Boydie) is offline
Quick Reply: Better Air Intake Setup?
