Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Fuel Injector Cleaning
Old 04-30-2015, 09:49 AM
Technical Moderator
You'll be lucky if you get an answer to a 4 year dead thread.
donbrew is offline
Old 04-30-2015, 09:59 AM
LawDog88's Avatar
db/sb is still around. He might be able to toss out an answer.
LawDog88 is offline
Old 04-30-2015, 03:23 PM
db/sb's Avatar
His question was aimed at ballplr. He is still around also but I don't share his enthusiasm for in tank fuel injector cleaners, so there is really nothing I can add.
db/sb is offline
Old 04-30-2015, 04:42 PM
Technical Moderator
Alls I knows about 44K is I can't afford it, even at cost + 10%. Cheaper to buy new injectors for about $80 than have them cleaned (just make sure you get the correct part number for your ECM program).
donbrew is offline
Old 07-28-2016, 09:17 PM
flamarallenjr's Avatar
Fuel injector cleaner
Well here go my take on an old thread about fuel injector cleaners. I've been using Marvel Mystery Oil for around 26 years and the results have been good. I put 216,000 miles on a Saturn SW2 wagon and used only M.M.O. in it and never had any injector problems. One really good use of this oil is an engine sitting for along time and not run is to pour this stuff right down the intake (or as close as you can to the pistons) it's will release the piston ring so they won't break on start up. Best results is to let set over night. Anyway thats only one more opinion.
flamarallenjr is offline
Old 08-05-2016, 08:48 PM
  #26
Drifter.'s Avatar
STP super injector cleaner in the BLACK bottle works! I have used it for years every 4 to 6 months my Z-28 TPI engine runs a lot better with an improvement in MPG as well.
Marvel Mystery Oil works also, actually it works for a lot of things. My old jeep had a sticky Loud lifter I added a quart to the oil let it run for 1/2 an hour.....no more noise. After that I decided to put some in the gas after a couple of tanks the old 4.0 is running smoother and 3 mpg better mileage. Might not work for you but it did for me.
Drifter. is offline
Old 08-06-2016, 05:41 AM
  #27
hurst2001's Avatar
Yep mmo is the best use 4oz to every 10 gallons of gas., for the oil 1 bottle 32oz and 4 quarts of oil run it about 2 thousand miles man my oil came out blacker then black and the engine runs smooth..😄😄
hurst2001 is offline
lauriej
09-22-2012 03:11 PM
JJ_HHR
01-06-2011 08:29 PM
HHRthunder13
2.2L Performance Tech
07-18-2009 05:41 PM
hookupny
06-11-2007 11:09 PM
poeg
03-07-2007 07:33 PM
Quick Reply: Fuel Injector Cleaning
