Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
How accurate is the MPG detector computer thing?
Old 03-05-2012, 02:02 PM
kornellred's Avatar
The MPG calculated by the computer cannot be wrong, if the diameter of the tires is the same as came from the factory, and the fuel injectors have not been changed.
Each pulse of a fuel injector injects a precise amount of fuel into the combustion chamber. Each rotation of a wheel advances the vehicle a specific distance.
To determine how much fuel is consumed, the computer counts the number of times the injectors are pulsed and multiplies that figure by the injector's delivery volume per pulse. (there may be pulse duration factors in there somewhere)
Simultaneously, the odometer is counting the revolutions of the wheels, and determining how far the vehicle has traveled. Computers cannot be partially correct. They can only be correct, or non-functional.
The trouble is that engines spend a lot of time consuming fuel while the vehicle is at a standstill. However, since standing still is also a significant part of vehicle operation, you are getting the REAL MPG from the computer.
kornellred is offline
Old 03-05-2012, 06:54 PM
Technical Moderator
Originally Posted by deliveryman
Are the 60's cheaper than the 50's on the tires? I may have to check on that because I replace tires about every 6 to 8 months. I drive about 100,000 miles a year and I have an 09 ls with 227,000 miles right now. My speedometer is about 2 miles per hour slower than what my gps shows with the stock size tires.
215 60R16 cost me about $75 - $100 less than 215 55R16 for a set of 4. I get the cheapest 65K - 70K guaranteed tire I can find.
I just got a photo speeding ticket the other day with the Cruise Control set at 66 MPH, the photo threshold is supposed to be 69 MPH in a construction zone in Maryland. The GPS was wandering around a bit 68 - 70, it was raining and going down hill. If you really want to, you can change the tire size with a Tech II scanner.
donbrew is offline
Old 03-23-2012, 03:26 PM
Technical Moderator
Today I put 15.938 gallons in the tank, and it did not overflow! I happened to have the Owner Manual out at the same time and noticed that the capacity is actually 16.2, I could have made it the Costco, darn it.
donbrew is offline
Old 03-23-2012, 04:31 PM
Black C5's Avatar
Originally Posted by Old Lar
...average mpg DIC...teaches you how to drive to maximize your mpg...The long term mpg has been 31+/-2.8 mpg (fillups 109) roughly 39,000 miles. Currently it is running 28+/-0.9 mpg (fillups 8) roughly 3000 miles. Statistically the values overlap with their ranges.
Wow! What GREAT record keeping
Black C5 is offline
Old 03-23-2012, 11:21 PM
deliveryman's Avatar
I put in 15 gallons even yesterday. I think it cost around $55.00 though. How much is the gas up there now? We are around $3.70 to $3.75 a gallon.
deliveryman is offline
Old 03-24-2012, 10:11 AM
  #26
Technical Moderator
3.83 mostly in my town, we are just the other side of the "emissions" line tThe other side of the river 3.95.
donbrew is offline
Old 03-26-2012, 06:23 AM
  #27
08LaRam's Avatar
I filled mine up yesterday and the electronic gage said I was averaging 25.2 mpg but paper and pencil said 30.1mpg. I rechecked and 30.1 is correct. I suppose the average is over many tanks of fuel and the 30.1 is just for this one tank...that would make sense. The next time I check it I will zero the average when I start on a fresh tank and see how close the average is to paper and pencil.
08LaRam is offline
Old 03-26-2012, 07:11 AM
  #28
True. Just reset your average reading after each fill up for accuracy.
firemangeorge is offline
Old 03-26-2012, 08:42 PM
  #29
rroadkilll's Avatar
This was on a recent trip... I reset all things at fill-up!!!
Notice the fuel gauge and mileage...
rroadkilll is offline
Old 04-07-2012, 06:42 PM
  #30
jay loukakis's Avatar
I have an 2006 2lt, mileage shows average MPG, always 17.6 around town or on the freeway 65- 75 MPH the average mpg stays pretty much the same as around town, the newer HHRs are more exact, can the computer be programed to show instant and average.???
jay loukakis is offline
Quick Reply: How accurate is the MPG detector computer thing?
