Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
How much?
Old 10-19-2013, 11:27 AM
LawDog88's Avatar
How much?
Here's a question I have after a night of idling in my car for a Security Gig that I did in MI.
I started the shift with just under 3/8 of a tank of fuel, and when I got home, I was down 1/4 tank(1/8 tank of fuel left)
My question is; What is the consumption rate for a 2.2L
What is the consumption rate for a 2.4L While idling.
What is the consumption rate for a 2.0L
I feel like 1/4 gallon of gas was a lot for a little 4banger.. But, I could be wrong. INPUT PLEASE!
LawDog88 is offline
Old 10-19-2013, 11:39 AM
That's a good question. I have no idea what the answer is.
SS fan is offline
Old 10-19-2013, 11:45 AM
Based on GM figures for their industrial engines....
5.3L V-8's (Gas) .75-.85 Gph at idle
4.3L V-6's .30-.35 Gph at idle.
2.5L 4's .20-.25 Gph at idle.
So burnng .25 gallons of fuel in a 2.2 at idle over a shift is about right, have to remember that idling engines get "Zero Mpg". If conditions and your duties allow it, shut her down as often as possible, restarting uses a fraction of the fuel used to idle.
And remember, excessive idling now puts you into the "Severe Service" maintenance schedule so you'll need more frequent oil changes to keep your engine healthy.
843de is offline
Old 10-19-2013, 12:17 PM
LawDog88's Avatar
So 1/4 tank over a night is about right?
I know I am about due for an oil change within the next 1,000 miles. Since I got home from travelling for work, my HHR has sat a lot, and my oil life is still around ~60%. That being said, when I get the chance, Mobil 1 High Mileage synth is what I am thinking to go with.
LawDog88 is offline
Old 10-19-2013, 02:52 PM
that would be idlic, so to speak!
Oldblue is offline
Old 10-19-2013, 07:03 PM
LawDog88's Avatar
I see what you did there Oldblue
LawDog88 is offline
Old 08-01-2014, 10:42 AM
gunblaize's Avatar
.25 GPH through constant idling of 8hrs puts you at 2 gallons of gas used
If your car has a 16 gallon tank, 1/8 of that is... 2 gallons.
gunblaize is offline
Old 08-01-2014, 11:18 PM
I would only add that running the fuel level that low is not a good practice..
sleeper is offline
Old 08-02-2014, 11:46 AM
LawDog88's Avatar
Ah, sleeper. Did you take an extra long nap, and find this thread a little late?
LawDog88 is offline
Old 08-03-2014, 12:43 AM
Talking
Kevin- Actually you should have asked gunblaize this, since he posted preceeded mine..
sleeper is offline
