Is the 2.4 worth paying the extra for?
Originally Posted by adamlowery
Does it help a car at all to use better octane gas? If so what does it do?
In the owners manual it claims that if you use anything less than 91 with the 2.4l then your acceleration will be slowed and you will hear a knocking noise...
Originally Posted by mtbiker-s
Maybe I'm mistaken, does the pinging sound like little rocks hitting the inside of tin can? Kind of like tick, tick, tick tick, tick after the engine has been turned off a couple of minutes.
I don't hear anything after I turn mine off, (I have the 2.4L). Try changing your gas, just too see, it sys that after you run the 91 or higher for a bit it should stop, if not take it to the dealer....but let us know either way, I'm curious on this....
Will post results upon my return
Exhaust Cooling Sounds
