2011 hhr trans module replacement
Old 09-03-2015, 07:56 PM
Tluzzo's Avatar
I just bought a 2011 hhr with 84,000 miles on it. i drove it 7 days and had to take it back to the dealer after turning in on and the engine light and the esc lights were on and the speedometer was not working and it would not go over 45 mph and started to over heat. boy was i surprised after just 7 days. Well the dealer was nice enough to replace the trans module at there cost. What other issue should i expect. Since all the reviews that i read where positive. I guess those who are having problems with this car did not have much input in cars.com. thanks if you can keep me inform of any other problems i might experience. Tom at XXXXXX@sbcglobal.net
Tluzzo is offline
Old 09-03-2015, 09:10 PM
Lucky's Avatar
Welcome to the site.
I have not seen a lot of failures of the trans controllers.
It sounds like the trans module shorted out the data bus.
All the controllers talk to each other over the data bus. If one controller locks up the bus then the other controllers know what's going on. That why you seen so many things effected.
Is the trans controller the only thing they replaced?
Lucky is offline
Old 09-04-2015, 06:39 AM
Technical Moderator
I edited your email so maybe you won't get as much spam.
Welcome!
The symptoms don't sound like a TCM to me. More like VVT valves.
donbrew is offline
Old 09-04-2015, 07:10 AM
Welcome to the site, were there any codes, to prompt the TCM to be changed?
Oldblue is offline
Spawn21
12-11-2015 12:16 PM
geg
05-18-2010 11:17 AM
ymerej_mortsdnil
11-04-2008 09:48 PM
Quick Reply: 2011 hhr trans module replacement
