AC Fan on 2011 wont blow.....
Old 09-18-2014, 04:05 PM
girlgonestupid's Avatar
Unhappy AC Fan on 2011 wont blow.....
just curious what might be wrong with the AC fan in my 2011 HHR. It stopped blowing consistently a couple months ago....for a week or so, then worked fine up until last week....I feel the cold, but the fan isn't blowing it into the car....sometimes it comes on within about 20-30 minutes, sometimes it doesn't. I have checked fuses....Do you think it could be resistor or maybe compressor, or the ac motor? I'm so broke, I don't have money to go buy all the parts and hope that I can figure it out....Thanks. Lisa
girlgonestupid is offline
Old 09-18-2014, 04:59 PM
Technical Moderator
I's either the resistor or the blower motor. My guess is the blower. Definitely NOT the compressor. Not good to run the A/C if the blower is not running (that's why there is an interlock in the fan switch to prevent it).
donbrew is offline
Old 09-18-2014, 11:03 PM
Lucky's Avatar
Welcome to the site
My guess would be the blower motor is failing. To find out you would have to do some tests with a test light of muti meter.
Being a 2011 could it be under warrantee or are you out on miles?
Lucky is offline
Old 09-18-2014, 11:35 PM
Grizzly old man's Avatar
There is a fan motor relay in the fuse box under the hood. That might be a fairly inexpensive fix.
Grizzly old man is offline
Greenied1
12-14-2014 10:37 AM
KISS_MY_SS
03-11-2014 07:56 AM
coreycooper
2.0L Performance Tech
21
12-19-2010 12:18 PM
Money in the Bank
09-23-2007 04:48 PM
hhrboutique
08-04-2007 09:56 PM
Quick Reply: AC Fan on 2011 wont blow.....
