AC: question regarding fuel consumption
Just curious regarding the AC's fuel consumption:
- When showing the current fuel economy in the DIC (MPG INST) and the AC is running, does the display show the fuel consumption including what the AC uses or is the consumption display only dependant on the accelerator pedal's position (or other parameters)?
- Does the AC/compressor always run under full load? For example, when the temperature control knob is not turned completely to the left side (maybe only somewhere in the middle of the blue bar), does the AC run under full load and warm air is blended in or does the AC "work" less?
I hope my questions are somewhat clear :-)
The A/C works off of the engine, not a separate energy source. The INST is a pretty useless item for normal purposes, best to not even know It's there.
The compressor is engaged at all times when the A/C has been turned on, either with the button or with the defrost or with the recirc.
A Crazy Canuck
Fuel Economy - Hypermiling
23
01-11-2013 06:29 PM
