air filter housing noise
Old 10-13-2016, 10:24 AM
motorcycleman58's Avatar
Just bought a 2006 HHR in Sept. On the way home from work started hearing a buzzing noise. When I opened the hood discovered air filter housing had com loose from its grommets. I reinstalled housing but still hear noise at anything over 25 mph. Anyone else run into this problem and how to fix it.
motorcycleman58 is offline
Old 10-13-2016, 11:00 AM
Welcome to the site.
Just guessing here but check the housing bracket and see if it's broken. Here's a link to 1 thread that shows the part and how the owner fixed his.
https://www.chevyhhr.net/forums/how-...bracket-42160/
firemangeorge is offline
Old 10-13-2016, 12:11 PM
Welcome to the site, the part number is in here on page 1
https://www.chevyhhr.net/forums/comm...-part-i-48833/
Oldblue is offline
Old 10-13-2016, 12:22 PM
Silverfox's Avatar
Also check the Oil fill pipe where it comes thru the air cleaner housing.
On one of my earlier HHR's my GM dealer found the bracket bent and that allowed the
Fill pipe to slightly touch the housing.
I later put on a new bracket and that cured it.
Silverfox is offline
Old 10-14-2016, 11:25 PM
air box noise
Thank you for the information. I will look at the bracket this weekend.
Pylonman
"How To" Tutorial Library
11-06-2016 12:56 PM
bigjacksauto
08-31-2014 01:10 PM
Quick Reply: air filter housing noise
