Broken door handle
Old 09-15-2013, 12:48 PM
Spade's Avatar
Broken door handle
Anyone had trouble with the door handles braking off? They are made from cheep plastic material. The cost to replace is outrageous, nothing cheep about that. Chevy should recall the door handles. Its wrong to sell that cheep mess knowing it would fail. How many HHR have had this happen?
Spade is offline
Old 09-15-2013, 01:14 PM
wmsburghhr's Avatar
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-fix-broken-interior-door-handle-less-than-%2410-41305/
Also see video
wmsburghhr is offline
Old 09-15-2013, 02:34 PM
Technical Moderator
Sometimes spellcheck is correct.
The CHEAP plastic door handles are not intended to be used as door closers, that is how they BREAK. That is what the hole in the arm rest is for.
donbrew is offline
Old 09-15-2013, 02:50 PM
After reading your other 2 posts, let me just say:
Take a deep breath and calm down.
This is a friendly and helpful website with some great HHR owners and members. Yes, Chevy was a little "cheap" on some stuff and some things do "break" occasionally, but it was built as an economy car so sometimes things aren't 100% perfectly designed.
And no it doesn't cost $400 to fix a door handle. Do a search here and you will find there is a much cheaper fix.
I know your new, mad and just trying to vent a little bit, but a calm post here will usually get better and more helpful responses.
firemangeorge is offline
Old 09-15-2013, 08:26 PM
X2!
whopper is offline
Old 09-15-2013, 08:50 PM
LowHHR's Avatar
I was recently at a dealership and they had a service magazine at the parts counter, in it there was a article on GM replacement door handle kits they are making. I don't know how much they are, but they seemed to be an improved replacement from GM.
LowHHR is offline
Old 09-15-2013, 10:40 PM
Check your local auto parts store for the Dorman repair kit, the PN for the left side is 80369, the right side takes 80370.
Simple to do, less than $50, and a touch more sturdy than the OEM handles.
843de is offline
Old 09-15-2013, 11:39 PM
x2 - and do not pull the door closed with the handle - use the grip built into the door panel.
whopper is offline
Old 09-16-2013, 05:44 PM
OK, here's the deal, some very nice folks have tried to address the door handle issue providing sources of repair parts.....and even part numbers in my case.
Continual posting of gripes about it in other threads is disruptive and useless, and it will not be tolerated.
That being said, take a deep breath or two, head to your local Napa, Autozone, advance, O'Reilly, or Western Auto and pick up a repair kit.
'Nuff said.
843de is offline
Pimphand
"How To" Tutorial Library
63
04-29-2022 10:06 AM
ladonne
04-06-2015 02:51 PM
marineswifey91
05-16-2013 01:40 PM
gottahaveheart
04-20-2011 04:39 PM
dreawilliams
10-09-2010 07:11 PM
Quick Reply: Broken door handle
