Broken wind deflector clip... - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 04-13-2009, 08:47 PM   #1
Cool Broken wind deflector clip...
I have also been a victim of the infamous broken wind deflector clip issue. I have read lots on this forum and before I found the actual part number of the clips I need, but I cant seem to find the part number anymore. I can fix the issue myself, just need to be order the parts... Can someone shed some light on my dilema?
pobryne is offline   Reply With Quote
Old 04-13-2009, 08:53 PM   #2
HHR_SS_QC's Avatar
Images: 62
For the sunroof?
HHR_SS_QC is offline   Reply With Quote
Old 04-13-2009, 08:56 PM   #3
Ya for the sunroof, I could put the plastic wind deflector on... but the wife doesn't like it...
Old 04-13-2009, 11:14 PM   #4
shaginwgn's Avatar
Images: 164
here is the TSB...
Quote:
Originally Posted by ChevyMgr View Post
Document ID: 2215429
#08-08-67-018: Wind/Air Deflector Bracket on Sunroof Module Broken (Replace Bracket) - (Dec 2, 2008)
Subject: Wind/Air Deflector Bracket on Sunroof Module Broken (Replace Bracket)
Models: 2006-2009 Chevrolet HHR
Condition
Some customers may comment that the sunroof will not close because the wind deflector won't fold down properly when the sunroof glass closes.
Cause
Attachment 4236
The end on the wind deflector retaining bracket may have broken off, which causes the wind deflector to function improperly.
Correction
Remove the headliner following SI procedures.
Open the sunroof and protect the interior.
Clean the sunroof tracks around the broken bracket.
Tape off the area around the bracket to contain the drill shavings in the next step.
Attachment 4237
Using a 1/4 inch drill bit, drill off the head of the two rivets.
Vacuum the drill shavings.
Using a small drift, pound out the rest of the rivet in the sunroof module.
Attachment 4238
Attach the wind deflector to the new bracket and clamp the bracket in place.
Using the holes as a guide in the sunroof module, drill 1/8 inch holes through the bottom of the new brackets.
Attachment 4239
Install two 1/8 x 3/8 inch long rivets (obtained locally) through the BOTTOM of the sunroof module to the new bracket.
Apply weatherstrip adhesive to the top of the rivet head.
Replace the bracket on the other side following steps 3 through 10.
Important: Make sure the tracks are clean and no metal shavings are present.
Cycle the sunroof several times to make sure the sunroof functions properly.
Reinstall the Headliner following SI procedures.
Parts Information
Part Number
Description
20794829
Bracket-Sun RF Frm SI LH
20794830
Bracket-Sun RF Frm Si RH
shaginwgn is offline   Reply With Quote
Old 07-15-2010, 05:51 PM   #5
Images: 1
My warranty doesn't cover this item because it's "trim" or a "hinge." Are those part numbers correct?
2003_2LT is offline   Reply With Quote
Old 03-06-2011, 10:55 PM   #6
I did the whole repair myself. Check out the details on my blog if you want to DIY it.
http://srikanajan.blogspot.com/2011/...of-broken.html
irshramu is offline   Reply With Quote
Old 03-07-2011, 06:56 AM   #7
Technical Moderator
Lucky's Avatar
Images: 24
Nice job you should put this in a " how to " on this site
Lucky is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Sunroof Wind Deflector cooltravlin Appearance/Modifications Discussions 11 04-25-2015 06:01 PM
Sunroof wind deflector bobnj Maintenance and Upkeep 2 12-13-2013 06:42 PM
Sunroof Wind Deflector Impressions Inactive Classified Ads 3 05-19-2011 10:15 AM
Sunroof Wind Deflector: Krusty Mods - Exterior 12 03-15-2011 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
