check engine light
I don't know why that would cause the "POWER STEERING" message. Also, should not affect the RS since it should clear itself at every cold start.
I think you need a new fiskerator solenoid.
chitownmike - when people here say 'post the the code", they mean exactly that - not a verbal description (which is what you posted). The reason being that the autoparts store will often give a verbal description which may be incorrect, resulting in one replacing incorrect parts.
In this case, the verbal description is likely good enough - if you use the SEARCH tool at the top of the page and look for thermostat, you will find info on how to further determine if in fact it is the offending part that needs replacement.
purple people eater
09-17-2016 01:07 PM
