Do I have remote start??
Old 12-09-2007, 04:22 PM
jjdurrant's Avatar
Hey, all. N00b here. I am trying to figure out if I have remote start or not. I understand all autos do except for rental hhrs which mine was. It is a 2007 LT silver. I have the four button fob (lock, unlock, panic and a circle arrow button which I would assume is the remote start button). However, the button does not do anything when I press it. Also, would the factory warranty still apply even if it was a rental? This has 21k miles and I think the front struts are shot.
Thoughts?
Thanks, Justin
jjdurrant is offline
Old 12-09-2007, 04:24 PM
dbarberaz's Avatar
yes you have remote start. Try this first, press the lock button then press and hold the start button on your remote. Should take a second and start right up
dbarberaz is offline
Old 12-09-2007, 04:36 PM
jjdurrant's Avatar
You rock! It worked and you saved me a couple hundred bucks. Thanks man!
Old 12-09-2007, 04:43 PM
Size:  5.6 KB to the site!!!
HillsdaleHHR is offline
Old 12-09-2007, 05:05 PM
an08HHR's Avatar
If you have the manual go to page 98 for instructions. If you don't then click on this thread link or copy and paste it
and then you can download the manual. The warrant still should be good.
https://www.chevyhhr.net/forums/general-hhr-4/online-owners-manual-3074/
One more thing, WELCOME to the site
an08HHR is offline
Old 12-09-2007, 05:58 PM
itschaboykenny's Avatar
jjdurrant pics
itschaboykenny is offline
Old 12-09-2007, 06:21 PM
If you ever forget, the instructions for "remote start" are on the back of the key fob.
jx3 is offline
Old 12-10-2007, 07:36 AM
jjdurrant's Avatar
THanks guys! Also, can the default 10 min runtime be changed?
Old 12-10-2007, 08:22 AM
an08HHR's Avatar
From what I know, the answer is no. It is sort of a safety feature so the engine shuts off after 10 min and doesn't run forever in case you forgot you started it and then took off with a friend in their car.
an08HHR is offline
Old 12-10-2007, 05:46 PM
jwolfe99's Avatar
Simple answer, No but if you do the same procedure again you can extend it another 10mins..
jwolfe99 is offline
Quick Reply: Do I have remote start??
