How should I go about putting an hour meter in my 2008 HHR?
Old 08-12-2017, 11:02 AM
RoofTopPigeon's Avatar
Would it be possible to wire an hour meter
into My 2008 HHR 2.2L
*So that it ONLY Counts
When the Transmission is in "Drive"?
RoofTopPigeon is offline
Old 08-12-2017, 12:25 PM
Technical Moderator
Probably wire into the DRL relay off the top of my head. I will think some more on it.
DRL
Park position switch
Or the PNP switch:
donbrew is offline
Old 08-13-2017, 08:10 AM
Donbrew; how would you go about that?
Old 08-13-2017, 09:10 AM
Technical Moderator
With wire.
I think what I would do is put the + to the purple wire (terminal 87) of the DRL relay. It will supply 12V when the gear selector is not in park.
Or to the yellow wire going to the headlight. Whichever is easiest to get to. Maybe with a relay, but not required.
donbrew is offline
hhrumadbruh
08-25-2012 04:40 AM
oneokie1
02-15-2012 09:29 PM
Lone Ranger
10-20-2008 12:57 PM
Quick Reply: How should I go about putting an hour meter in my 2008 HHR?
