Door lock buttons
Door lock buttons
Have a new 2009 SS. The only thing I don't like is the location of the door lock buttons on the front door. They are right were I want to put my arm with the windows open. Anyone have a solution? Except for not putting my arm there.......
After you cut them, you most likely won't be able to use your fingers to pull them up, so you need to carry a break out tool in the glove box, just in case you need to get out of the car in a hurry and have no battery power for the electric locks.
Or....Leave the pass side a tad higher to be able to grab..
Cut mine down with a small cut off wheel used a piece of anodized aluminum tubing aka knitting needle and capped it with a piece of plastic... Silicone on the inside
BATMAN- used the pointy end of the needle (hope you don't mind I pilfered your pics... Caped Crusader)
RUDEINC
40
01-03-2008 07:54 AM
nfboy
06-27-2006 07:18 AM
cj krause
7
04-23-2006 09:02 AM
